Weather cloths
In Response To: Weather Clothes Ideas? ()
You want to make sure that the line you use will be the weak link in the system... if you get dunked with green water you want the lines to fail and let the water find it's way overboard without taking your stanchions with it. Of course that only matters if your sailing area puts you at risk. I used a couple of wraps of waxed mousing twine on mine and replaced it every time I put them up.
