FWIW...
When you do the skeleton construction, I don't think I'd butt weld the strap to the shaft, but rather wrap the shaft with the strap then weld. The weakest point is the weld and if it breaks your tiller will turn, but the rudder maybe not so much. I noticed when reading about comments on rudders, that this can happen. Of course my comment and $0.50 will get you a phone call.
