Tom what you are seeing on the pictures above in increased jpeg compression...
Changing file size alone generally simply involves changing the compression. More compression = less detail. If you think you can see the difference between a picture at 150 dpi and one at 300 dpi, saved at the same level of compression, on a computer monitor, then you have a good imagination.
