16. Testing:When launching the boat,inspect the PSS and make sure the PSS is properly in place.Water should not be entering the boat from the PSS seal area.Run the engine in gear as in a normal operation.It is normal at this time to notice a very fine spray or mist coming from the seal and some carbon dust,as the PSS requires a break in period (see below).The PSS should not be leaking at rest and should never spray more than just a fine spray or mist.
Paul L
