Return to Index
Read Responses
You do have a vibration isolator on the shaft?
In Response To:
Damn! Does a dripless leak when new?
No it shouldn't drip at all
You sure the mating surfaces weren't scratched or gouged during install?
I let Hinckley do the work.
Yeah that is a lot of pressure. It's probably fine.
Here's the notes from the PSS shaft seal on dripping and spray
Also don't forget the thrust of a prop underway will reduce pressure on the seal
I call the guy that install and see what he say
That should have been I would call the guy
No, not much pressure at all.
Yes, just installed one and it leaked.
