Return to Index
Read Responses
There is an extensive study of bottom paint options in this month's Practical Sailor
In Response To:
Water-based bottom paint?
I've been using Hydrocoat. I too had a few pounds of shellfish stuck to the keel last fall.
I've had good luck with Hydrocoat
Same here in Western LIS. Hydrocoat works well
We used Hydrocoat
That is pretty bleak.
I have used ACP50
I have been using hydrocoat for about 5 years...
How much do you apply every spring Todd?
I have a marker coat under the working paint...
A full coat takes a gallon
Another Hydrocoat user
That's about where I am with it.
About the same as you, Tom
If we didn't do anything, would the results be that much different?
This same thread is ongoing on the other board.
Around here there would be a HUGE difference
Need bottom paint
Towing my inflatable from Mobjack Bay, around to Texas, Sept thru Dec
