Return to Index
Read Responses
That's about where I am with it.
In Response To:
Another Hydrocoat user
It's not great but not that bad. How much did you put of before launch?
http://usharbors.com/
Water-based bottom paint?
There is an extensive study of bottom paint options in this month's Practical Sailor
I've been using Hydrocoat. I too had a few pounds of shellfish stuck to the keel last fall.
I've had good luck with Hydrocoat
Same here in Western LIS. Hydrocoat works well
We used Hydrocoat
That is pretty bleak.
I have used ACP50
I have been using hydrocoat for about 5 years...
How much do you apply every spring Todd?
I have a marker coat under the working paint...
A full coat takes a gallon
About the same as you, Tom
If we didn't do anything, would the results be that much different?
This same thread is ongoing on the other board.
Around here there would be a HUGE difference
Need bottom paint
Towing my inflatable from Mobjack Bay, around to Texas, Sept thru Dec
