I have the Moeller mechanical in aluminum tank
Still working good after 20 years. I just had it out to clean and inspect the tank and it looked fine. It's going to be a pain to install though, since you have to drain the tank and clean out all the aluminum shavings when your done. You can create a calibration chart when you fill it back up.
I had a "calibrated" dipstick on my last boat and that worked fine too.
