I have had CNG until this year so this is my first year with LPG. The documentation says with the stove burners closed and the line pressurized, when you close the valve at the gas tank, leaving the solenoid open, pressure should be steady for at least 5 mins. My pressure drops like a rock. I cant find a leak with soapy water on every conceivable fitting. What could be the problem?
