Return to Index
Read Responses
no. thats a good idea. thanks
In Response To:
Have you run the pressure test with the solenoid closed?
Propane issue?
You have a leak!
You have a leak ...
Do you have a shut off at the stove Doug?
Unfortuately, no
This is worrisome. I'll tell you what, I'll trade you my CNG system and stove.
I like my CNG... of course useless for anywhere but the states...
I've spent a small fortune on CNG tank exchange.
No, low side was $30 in Onset!
Oh that's right, I knew it was cheap.
Wow, only 5 min.?
No valves on back of stove.
Specialized crimping is required on the hose isnt it?
Not sure what you mean, but...
No tape or dope on most modern stoves...
Roger, no dope on a flare fitting
Good idea. You've done what most of us could do.
Don't rule out the regulator.
No smell,Al but I did notice
That could be it! Bad gauge. Do you see rust around it?
Drop like a rock or goes to 0 ???
Are you using a QC connector?...
