Return to Index
Read Responses
Drop like a rock or goes to 0 ???
In Response To:
Propane issue?
When I had a small leak you could smell it. When a burner is first lit you can smell it.
Propane issue?
You have a leak!
You have a leak ...
Do you have a shut off at the stove Doug?
Unfortuately, no
This is worrisome. I'll tell you what, I'll trade you my CNG system and stove.
I like my CNG... of course useless for anywhere but the states...
I've spent a small fortune on CNG tank exchange.
No, low side was $30 in Onset!
Oh that's right, I knew it was cheap.
Wow, only 5 min.?
No valves on back of stove.
Specialized crimping is required on the hose isnt it?
Not sure what you mean, but...
No tape or dope on most modern stoves...
Roger, no dope on a flare fitting
Good idea. You've done what most of us could do.
Don't rule out the regulator.
No smell,Al but I did notice
Have you run the pressure test with the solenoid closed?
no. thats a good idea. thanks
That could be it! Bad gauge. Do you see rust around it?
Are you using a QC connector?...
