The soapy water trick is only good for small leaks. If the leak is too big, it just blows the soapy water out of the way and no bubbles form.
I'd try disconnecting stuff and then putting your thumb over the pressurized end and repeating the drop test. Work your way back to the regulator/gauge/solenoid until you get a good pressure test.
