Return to Index
Read Responses
I don't see the problem
In Response To:
I’m currently running a Cabo Rico 42 north, a gorgeous boat… HOWEVER...
I can see both the chartplotter AND the magenta line. You are good to go on the ICW...
Mark
http://www.svreach.com
The impairment to visibility is not the worst of this arrangement, however…
Jon, that's 'cause you're standing where the table should be
Jon....
Which is why I built my own....
Me too.
That is one mighty fine piece of user interface engineering!
Yep, everything is a compromise...
There's no traffic, so there's no problem... LOL!!!!
Problem solved !!!!
With that many gizmos, I'm surprised you need to look Jon.
Has anyone seen the latest Garmin ads in Sail Magazine?
Now, if they could just
Automatic routing has been onboard....
Might want to interface with AIS as well. Steer around barges!
I'm surprised there isn't.....
obviously, they hired the wrong person for the delivery
Real men stand at the wheel?
Or steer from the coamings?
Or, is this the new Edson man, invented in the 60's?
Yup hard to put an instrument pod in the middle of an empty deck.
Can't you just run it from your home using the new ICW app on your i-phone?
Wrong placement
I woundn't agree with those placements
Don't worry about the other boats. They'll get out of your way.
