Return to Index
Read Responses
If the hub is lapped and fitted the key will never be a factor
In Response To:
I like the BRONZE castle nut with the SS pin. if you
The hub will not turn on its own.
Prop Shaft Nut ... castle nut w/SS pin or brass Nylock Nut ...
I would not use brass in sea water.
Agree - assuming...
Yes to all of the above (but no to brass)
If you get down hard on the
Excellent, THANKS so far ... cheers, John
I don't know how people change props in the water
I wouldn't try to change a feathering prop
A few weeks a Swan 70 something
i just did the whole process in the water
We did....
That's a neat method. Like it!
As a matter of FACT....
