Your post makes me think it's a good idea to keep a length of right-sized plastic shaft aboard, to facilitate emergency prop repairs where there aren't any haul-out facilities. It would be easier to replace a shaft by that method than to replace the prop (alone) in the water. (easier to de-couple the shaft working inside the boat than the prop hub working from outside underwater).
