Don't you isolate the batteries with a switch?
In Response To: Pactor heads up ()
I would think that turning off the power to everything would be sufficient... although likely you probably run the radio gear right off the battery. Perhaps you need a second DC switch to isolate the RF gear. About the only thing I would want connected to the battery when "everything else is off" is a bilge pump. And I still have not yet installed a battery operated bilge pump. (gotta make a hole in the boat for that...)
