Wow, group 31s eh.
In Response To: Before you say it.... ()
And that is only part of the house bank?
I guess my group 27s are a joke for any long term cruising. I think I have something like 160 AH total... and I don't have separate house/starting banks, just an A/B switch. How big is your starting bank... just one group 27 or so?
BTW that battery problem I was discussing here a few weeks ago, indeed it was just a loose connection. I stripped the wire and crimped on a new ring lug (with a good ratchet crimper), and added lockwashers to the stack, while also eliminating a couple of connections that turned out to go to some long unused PO equipment. I also found out my battery monitor doesn't work, so eventually I'll pull that out too. But otherwise, everything is charging and working just fine now. Slowly but surely I am getting into all the nooks and crannies and removing "bugs."
It is amazing how that boat project list works. GRIN
