Return to Index
Read Responses
I try to buy it locally, but sometimes it's hard to find. Just in case this helps someone: Amazon has Red Devil butyl.
In Response To:
Red Devil is better
ports
Use butyl rubber calk or tape
get it here
Does anyone know what the shelf life of this tape is?
I was wondering that too.
most of the stuff I buy in tubes ends up in the trash.
In the tropics I had to replace tubes every year.
Anyone want to split an order with me?
Larry...
Thanks. Sent you an email
What have you used this on? Time frame?
I am using this on my Ariel right now.....
Hmmm. It sounds 'easy'...speaking of why things take so long....
It is, it does!!!
You guys said it. I challenge myself to build outside of the boat.
"...more work, off the boat."
P.S. Ain't it the trut'! Each idea leads to another and another and before long you rebuilt the boat.
Agreed, although you do still have to have other stuff for...
Yes, the "never again" was a bit of an exaggeration
Agreed
(Just had the topic on my mind as I was deciding what to use for fuel fills)
Sometimes you need "splooge", you can't get that with this.
You may already know about this, but there is also butyl caulk in a tube.
I didn't CCA.
Red Devil is one maker; also Ace brand.
Red Devil is better
Most states...
Hmmm, so you find that it doesn't keep water out effectively?
I disagree with Maine Sail on the suitability of the butyl caulk
Maybe I'll be okay then... thanks for sharing your experience.
Don't re-bed...
Thanks...
On this note...
Hey Westie, I have some.
Thanks, Hagar, I'm as yet undetermined..
How temperature dependent is this butyl for installation?
I have been using it in those temps
A caveat in colder temps...
I replaced the fixed ports on my C&C27 last summer
