Our 2500 watt inverter was connected with Locomotive Cable
In Response To: Large capacity electric cable ()
At least that is what is embossed on the jacket. It looks similar to welding cable with fine strands. The ends were crimped and sealed with heat shrink. That was in 1990 and it still looks good. You could leave several inches extra at each end so if you ever had a problem you could cut it and redo the terminals.
