Return to Index
Read Responses
Ridged needs to be registered. Had that problem myself. Different than Craftsman.
In Response To:
Home Depot BEWARE!
Home Depot BEWARE!
Did you buy separate "batteries" or just the drill w/ the original two-sets?
Sears replacement, not any more
I busted a Sears ratchet
Sears vs. Craftsman
The set
Just bought the same set...
In the Details
HD
I wired a Makita 9.6 volt drill that way. Ran fine on the 12 volt
I made a long 12 volt wire with battery clips for our B&D multi tool set.
We also use
I purchase ours when I needed to cut some plywood for overhead lighting.
Ryobi drills
Makita or Bosche
