Return to Index
Read Responses
as I use about a 1/2 GPH at WOT, is it really an issue?
In Response To:
Idealized flow a MAXIMUM pressure rating.
Well here is an interesting catch-22...
Bingo....
The fuel pump on the starboard side has a "clicker" to manually pump for bleeding.
Yeah, I figured I'd have to click away at that... but prior to that...
Uh ha! Just figured out why I can't find the electric fuel pump...
Oh.....
Sorry... the pump is in the PSC diagram...
GeneC, On Guenevere
I was going to post the same thing.
Cool idea guys. Might just do that.
Something to note...
I'm confused, 'primary filter', 'main filter' 2 micron ??
Aint so......
Then I will stand corrected on the 2 micron engine filter.
Im conversant in 'filter jargon' ....
Yup, Racor R20S
It will be if your filter cartridge has 'closed down' because of debris capture
to crank the engine, do this
Better way to crank with no worries is
