Return to Index
Read Responses
In Response To:
Im conversant in 'filter jargon' ....
Well here is an interesting catch-22...
Bingo....
The fuel pump on the starboard side has a "clicker" to manually pump for bleeding.
Yeah, I figured I'd have to click away at that... but prior to that...
Uh ha! Just figured out why I can't find the electric fuel pump...
Oh.....
Sorry... the pump is in the PSC diagram...
GeneC, On Guenevere
I was going to post the same thing.
Cool idea guys. Might just do that.
Something to note...
I'm confused, 'primary filter', 'main filter' 2 micron ??
Aint so......
Then I will stand corrected on the 2 micron engine filter.
Yup, Racor R20S
Idealized flow a MAXIMUM pressure rating.
as I use about a 1/2 GPH at WOT, is it really an issue?
It will be if your filter cartridge has 'closed down' because of debris capture
to crank the engine, do this
Better way to crank with no worries is
