 () One is adding extraneous metal underwater for all the reasons a person already knows. The other is, you don't need the weight on the rudder. A bit of engineering thought should produce a plate that would be adequately strong. I don't believe it needs to be that large, however? I think it would be a worthy experiment to do.
