dammed if you don't. I guess the case can be made for just sticking a knife through a sink hose to produce a very small leak the will eventually sink her and not one so large as to endanger yourself. Like you say, you have to think of you and your crews safety first. There is a lot of stuff floating around out there ans adding a broken boat to the mix isn't ideal but dieing isn't such a good idea either.
