Maybe the prop is slipping on the rubber hub ?
I've had two engines, a Suzuki 60 and Suzuki 6, where after much use the prop started slipping on the hub. Had to have a new hub pressed on. That said, when it happened to my 6 HP I was in an out of the way place and drilled and tapped a bolt to hold it on as a temporary fix.
