Return to Index
Read Responses
At rest
In Response To:
Photoday! Another coastal sailing season is coming to an end. What's a season?
At rest
TI Sunset
A hard rain
Useing it.....
A choice of plastic question for DDW
Look at UHMW PE tubing
Wall thickness too great
HDPE or UHMW Polyethylene are probably what you want...
I ordered some HDPE in 5/16" ID
HDPE and UV?
thanks for the reference
WW2 flaregun
does it work? It is a beatiful piece...
4 lbs
I've got a Nazi one from WWII. Thinking it's 26MM, too.
A pair of those tucked into your sash would definitely give you the pirate look
Should have read Gene's post first
Where Wile E. goes on the 3rd of July
Soccer is a dangerous sport
Yeow! Best of luck to her!
