HDPE or UHMW Polyethylene are probably what you want...
PEX is of course cross linked PE, the main advantage is high temp or chemical resistance, not much advantage in this application? It the cable really 1/4? or 6mm? If 6mm you could use 1/4 ID, if its really 1/4 you probably need to find 7mm or 5/16 ID. PVC and maybe polypropylene would probably work well too. I think the enemy is mostly going to be UV. PEEK would be great, stiffer and much stronger than PE, but the price will make a strong man faint…and then we get to Torlon and Vespel and Ultem at national dept type pricing.
McMaster has a pretty good selection of these in different colors. I would stick with opaque to keep the algae from growing inside.
