Return to Index
Read Responses
Should have read Gene's post first
In Response To:
A pair of those tucked into your sash would definitely give you the pirate look
Photoday! Another coastal sailing season is coming to an end. What's a season?
At rest
TI Sunset
A hard rain
Useing it.....
A choice of plastic question for DDW
Look at UHMW PE tubing
Wall thickness too great
HDPE or UHMW Polyethylene are probably what you want...
I ordered some HDPE in 5/16" ID
HDPE and UV?
thanks for the reference
WW2 flaregun
does it work? It is a beatiful piece...
4 lbs
I've got a Nazi one from WWII. Thinking it's 26MM, too.
Where Wile E. goes on the 3rd of July
Soccer is a dangerous sport
Yeow! Best of luck to her!
