If you let the AC unit drain down there you will get the "gooh of life" odor. You can get a shaft seal (PYI). Drain your AC units and shore sumps into a seperate sump and keep things smelling a lot better.
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=11151&productId=443307&langId=-1#.UqfzHX-9KSN
