Return to Index
Read Responses
question Greg
In Response To:
THINK DRY!!!!
Is this product also fine for the gland on the rudder post? I will be ordering this weekend.
Next Question....
here's a diagram
Having replaced mine in this past year...
The "pot" is fiberglass
So..you don't
It may be there for a reason...
In all those the "key" was the 12 inches below the injection point.
You want it as LOW as possible.
It's wet because
THINK DRY!!!!
It's gotten so I sort of think of using the bilge for storage...
OK, I'm interested
We (try to) keep ours dry.
question Greg
I am not sure....
I'm not sure this product will work on the Rudder Post ...
There are some methods of pumping it out to keep it pretty dry
Rule makes a sump kit with a built in pump kit
Not really...
In the extreme, yes; however,
See the link in JDM's post below from Vernalift.
It seems that with every boat question...
The waterlift muffler needs to be a minimum of 12" below the water injection point...
