Replacing my Galley Countertops with Corian or similar and new epoxy sealed marine ply 1/2" sub-top. Possible I can re-use my existing fiddles, which are fastened by screws & teak plugs to the old 3/4" ply w/Formica laminate tops, if I can get them off without damage, don't yet know if they are also glued. My fiddles are already sort of low, they only stand proud of the counters by about 1" … and I'll lose another 1/4" with the Corian and sub-top. So, unfortunately will probably wind up with new Fiddles … How high are your Galley countertop fiddles over the countertop surface ? Thanks, cheers, John
