Return to Index
Read Responses
27" or ???? monitor hooked up to your laptop USB cable..
In Response To:
Dare I ask - how to watch movies aboard?
SO cute?? or really dangerous
Max, you're in Maine correct?
Yes, sent an email Nat
We've ditched DVD's
Hmmm, we have an Apple TV at home
You could use a larger invertor.
Dan consider a 12v adapter and ditch the invertor
I had a 12 volt to 22 volt adaptor for the computer.
I delt with the issue both ways. Brendon
Hey Max
I think with Apple TV you need a robuust wifi connection. No? Please explain?
You can create an Ad Hoc network
Thanks, Charlie.
Yes.
Ok.
Max, On Guenevere
We just got a TV with DVD build in
We also run our sound
We have a 19" Flat Screen, it is not permanently mounted ...
If you look at the brick on your TV's power cord..
Here's something similar, runs on 12V
That is drawing as much power
Mostly just for a movie, say 7 AH doesn't seem bad
In addition to
I pipe them to the Raymarine, which keeps you from having to view boring charts & radar while on watch.
TV with DVD...12 volt...
Hard drive on a TV with a USB port
The LED backlit TVs use less power
Mark, which method do you use to gather the
It is a combination of downloads, copying from others and ripping from physical discs
Copy to hard drive....
I bought a "media Player" for about
