Doesn't sound right.
In Response To: Yikes it's hot in there ()
The Trident web site lists the valve as drawing .79 amps at 12 volts (that agrees with what ours draws) which is only 9.5 watts. That should only make it slightly warm to the touch. Do you have a way of measuring the actual amps?
