Most low pressure solenoids can not be used on the high pressure side. I prefer to place my lock-off valves on the high pressure side so there is less chance of a connection leak, regulator failure etc... The AFC solenoids can be used on either side which is nice.. The low pressure type fro Trident etc. must be used on the low pressure side.
