Return to Index
Read Responses
You flying or sailing?
In Response To:
Gene, The way mine works is the line from the back of the boom (inside)
How to calculate loads... for outhaul for instance.
With a 6 part....
I saw a 5 part that looks like it might be perfect.
The loads aren't even or equal at the head, clew, or tack.
I tend to agree about the routing issues.
Outhaul
What I have now is a car.
sounds like our Seldon setup
I do have halyard winches on either side.
or you could use a cam cleat like Steve said
True, that would work.
Oops, that's how my reefing lines
I would also suggest that the cam cleat
Would a Harken Magic box work?...
I hear you loud and clear about the comfort factor.
