Return to Index
Read Responses
Some engines are designed for electric fuel pumps, aren't they?
In Response To:
The short answer is "probably"
diesel fuel system question
Bleeding a Yanmar
Dahl
It is my understanding that there are
The tank is full, to the top full.
You might be able to change the petcock
I suspect you are right
Like Westerbeke.
Some Westerbekes -- no all.
Most engines that I've been involved
Of my three (two Westerbeke and on Yanmar) didn't require electric pumps.
Yes, but say you run out of fuel because
Nor do the Nissan diesels. The Bosch hand pumps are all you need.
That's a pretty good looking pump.
That looks like the one I had on my Toyota
As long as you didn't crank it over...
And that's true even if you had to bleed
I did not
