I did not crank it over, that would have covered my step ladder with antifreeze. I'm headed back down on Friday and will try to tighten that petcock. In theory it sounds like everything should work once we are in the water. Worst case scenario is that the engine does and I have to tie up at the fuel dock to bleed the lines.
Thanks.
