Return to Index
Read Responses
hmmm 20 amp hours a day...
In Response To:
I installed a Sea Frost BD series this spring
What sort of battery bank do you have?
So any of you with AB refridgeration...
A pair of 6v and one 12v, group 27?
It's a slippery slope
We use as little as 30 amps a day...
Damn big icebox space actually...
Don't feel bad guys, I burn about 80 amps per day.
Hell, I needed to run the generator
You also had a tri-fuel Yamaha...
The tri-fuel 2K Yamaha is for the home
Dan, I miss led you a bit. The 80 amps is
Larry, why don't you dump that thing
I second the endorsement of Engel
Definite 3d
Sure thing Steve
That's a big hardship - having to get up from the nav table to access the beer....
6.66 qubic foot...
Meant to say 200 ltr is 6.6 cf.
dumb question
Good question... it used R-12.
Gene, If you plan on replacing your AB
We have a BD50
Gene, I would be remiss if I did not jump in.
