Return to Index
Read Responses
Hose was not below the water line...only one clamp
In Response To:
Did you have double hose clamps on the hoses?
High water alarm and bilge pump counter recomendations
Wow! I'd like to see a picture of that clamp
How about these....
I got nervous reading Compass Marine and others
There are self almalating tape that works well on as emergency fixes
Search the web for Water Witch bilge alarm/counter
I have Borel
Link to Borel
Dual Approach - Counter and Alarm
"Lucky to be there when a big one let go..."
I think it's a practice that is admirable -- but answer: No, I don't
admirable, hell, I do it out of fear.
Irony
If you use a counter, be careful which automatic pump you get
If you pump cycles that often?
The pumps he is describing work that way
Rule makes them...
I feel so inadequate
It is in a 78 year old wooden boat
I know the feeling... I only have a manual pump.
Hope they're fused separately.
Each pump is fused..
On quiet nights it's...
Then how did water flood in?
Hose was nit supported and fell down
I'm still confused - the thruhull was below the waterline but the hose was not?
I thought Jeremy was speaking of the top side of a sink drain
