Back when I lived up North, I always used Vodka. I'd run the system dry and then run Vodka into the pumps and lines. I'd buy a gallon or two of the cheaper stuff. And if you have any left over, you are required to drink it. Using Vodka did away with the lousy taste that the "pink stuff" always left in the system. CHEERS!!
