Return to Index
Read Responses
Isn't it biodegradable? It goes into the sea.
In Response To:
Just curious...
Winterize fresh water system with air
It might be better to blow back from the fixture
How do you attach the air pump hose?
With a Water Bandit
I think you will do better...
Yes - plan to run the pump dry
dinghy pump vs. shop vac
Agree with Todd that teh shopvac is much
I've used the same technique as you
In Maryland
I alway used Vodka!
I did mine twice that way...
water heater
Mixing Valve Winterizing ?
I have the same Isotherm...
Winterizing fresh water system with air
I'm glad it worked out..however
Just curious...
I donno... I don't use the stuff.
I think it's alcohol, some colored dye, and water.
It's classified as non-toxic
And the hot water heater?
I drained it
simialr process, minus the vacuum
Does the main tank have a vent?
No adapter
My boat is like a summer cottage. It has copper piping that splits in the lightest freeze.
yeah, I agree - stay with the pink stuff
I think I posted last fall about how the yard did
Dunno about the timing for this thread. Always good to plan ahead! I drain the tanks with a pump...
Been doing this with a shop vac for years . . .
