I've used the same technique as you
Forever, well since I've owned boats starting around '80 or '81. The problem is that the pink stuff grows fungus in the tank and in the lines, and it tastes bad. I shock the system with chlorine each spring, but it takes a few cycles to get all the antifreeze taste out.
