Return to Index
Read Responses
That's it!
In Response To:
If your phone goes on "roam", then the power needs go much more than if it's locked into a "friendly" digital signal.
Love seeing EDGE every year at Harbor Island.
Sailonset
12 volt dc receptacles and plugs.
pretty harsh words for those poor plugs
I didn't mean to hurt their poor little old feelings! ;o)
I have one cig plug socket that kinda locks with a twist
Craig, heavy resistance or other loads are precisely those that a 12v cigarette lighter outlet shouldn't be handling
I see your point
I've never seen an laptop draw more than 6A
At what voltage, Larry - 120v @ 6 Amps is a lot of amps at 12 V (like 60)
At 12 volts
I have a brand new Intel 7 CPU machine on our boat with and digital hard drive and an 12" LED display.
How many amps does it measure?
This off the web -- HP Laptop
That's a pretty old machine they're showing
Here's some additional sources...
Looking at my Dell power supply...
Plug it into an ammeter
You have to be able to handle load peaks...
Also you can do a lot in "settings" to save power
I just plugged my Macbook Pro into the cigarette lighter charger
USB Charger
Here's something similar on eBay
While I agree ...
USB for Apple's iPad requires more amps, doesn't it?
I put them in "airplane mode" to charge.
Need a proper charger
The Blue Sea Systems one claims to be 2.1A.
That's it!
They need 2.1 amps
Have you seen the.....
The 12 volt cigarettte lighter socket is far
+1
12V Cig Lighter Sockets
