Return to Index
Read Responses
You have to be able to handle load peaks...
In Response To:
Plug it into an ammeter
otherwise you basically have a "crippled machine" and may as well just use an ipad.
12 volt dc receptacles and plugs.
pretty harsh words for those poor plugs
I didn't mean to hurt their poor little old feelings! ;o)
I have one cig plug socket that kinda locks with a twist
Craig, heavy resistance or other loads are precisely those that a 12v cigarette lighter outlet shouldn't be handling
I see your point
I've never seen an laptop draw more than 6A
At what voltage, Larry - 120v @ 6 Amps is a lot of amps at 12 V (like 60)
At 12 volts
I have a brand new Intel 7 CPU machine on our boat with and digital hard drive and an 12" LED display.
How many amps does it measure?
This off the web -- HP Laptop
That's a pretty old machine they're showing
Here's some additional sources...
Looking at my Dell power supply...
Also you can do a lot in "settings" to save power
I just plugged my Macbook Pro into the cigarette lighter charger
USB Charger
Here's something similar on eBay
While I agree ...
USB for Apple's iPad requires more amps, doesn't it?
I put them in "airplane mode" to charge.
Need a proper charger
The Blue Sea Systems one claims to be 2.1A.
If your phone goes on "roam", then the power needs go much more than if it's locked into a "friendly" digital signal.
That's it!
They need 2.1 amps
Have you seen the.....
The 12 volt cigarettte lighter socket is far
+1
12V Cig Lighter Sockets
