It was the only Sabre 386 built with a generator and they got it in when the deck was off!
At 20" by 19" by 30" it is substantially larger than the Fischer Panda.
You are probably correct though. This may all be a bit of a pipe dream and once I go through the exercise of "designing" the installation I will probably give up! I will report back as I decide...
