Return to Index
Read Responses
Well, that's what I'd do with a lot of sea room. Sounded like not so much there.
In Response To:
Putting up the main sail will absolutely help but
boat handling question
All I can think of, is putting up the mainsail.
That's what I'd do, sheet it in tight.
I think the waves are less swell that short, conflicting "chop"
Chop is tough. That's for sure. I was thinkins
Not much to add but I have a question
Agree moderate sped is your friend
Thanks for posting that. What a unique situation there.
Horseshoe Pond
You can try turning eaxctly
Avoid crowds
Perhaps a bigger boat??
Hey hon, Al said...........
Presque Isle Bays (those tricky trappers used the same name more than once) :^)))
you can now
It's good to see the system works
