I thought the stock Gunboat is pretty fast
I'm probably not alone being a little skeptical about fitting foils on a "cruising" cat. At some point I think you need to consider it a "sport boat" or "performance boat" no matter what the size, and I think that example is well beyond that point.
I bet it would be quite a calamity even in a "soft grounding".
