Return to Index
Read Responses
I guess the head mistress has retired...
In Response To:
The best manual head?
Have not heard from Peggie in quite some time.
Can't say which is best
This is why I say "installed correctly" on the Lavac...
might be easier to compare problems?
Without doubt, the Lavac Popular....
Above I originally wrote Vacuflush but I meant Lavac
I would encourage you not to judge it by that experience, Larry
EXACTLY!!!! ** LaVac **!!
I've had good luck with two types
How often
Hi John
Thanks Max
Hi John
I have had good service from my Wilcox Crittenden heads..
WC
MY WC is on my Allied 36
Yep...but I still lurk the sites that are worth reading...
You're hardly forgotten Peggy
You're not forgotten Peggie
you remain my supreme authority!
Still remember you. Your book is a referencr
Good to hear from The Doyenne of Discharge!
Good to hear from you Peggie...
Thanks for all the kind words!
Thanks for all the good work... as you can see, you are loved and appreciated here.
As Lauren Bacall once put it so perfectly...
I'll second Larry on the Raritan
That's why
Check out the Raritan "Fresh Head"....
I'm not sure
My Raritan II uses fresh water...
That's a nice modification
Well there is only one basin worth of gray water...
Composter toilet?
Can you give of some specifics Nat?
John, I don't know what brand it is though they all
thanks Nat
A suggestion - perhaps NO head.
What's his reason for sawing the rods?
I thought so too..
I'm skeptical
I'm skeptical too..
Thanks for the advice
A couple of install tips.....
Nice installation -- what is the flexible pipe?
That is not flexible pipe, but clear PVC bent to fit....
As aquick note. Once you get the spring
Interesting method, but...
I suppose that if I were to use the method
Maybe a crazy idea, but . . .
Two potential problems....
