Setting up this spring and bending jig seems like a lot of work, and I don't have a lathe. . . . But . . .
Why not just use plain old 1 1/4" DWV PVC and make the bends with the solvent glue plumbing fittings that go with them? I am thinking of using two 45* elbows to make the right angles so the bends aren't too tight for the effluent. And as long as I am getting the heat gun out. . . . Can't I get the 1 1/2" head hose to stretch enough to go over the unmodified 1 1/4" pipe with the application of a little heat? The whole assembly could be roughed in with the PVC fittings, with the pre-mounts sanitation hose cut to size for the fine tuning. . . .
I don't really need to see what I ate . . .
Am I crazy?
-- Karl
