That using a pressurized manual pump makes so much sense. If I'm going to use a manual head, I likely don't want pressure water. I've been planning on a dedicated FW tank to just pump manually from. Does this manual/ pressure combo work from the main FW system and pump? ( I thought that was a no-no)
